In professional concert sound system design, subwoofers can be incorporated seamlessly with the main speakers into a stereo or mono full-range system by using an active crossover. Such a system receives its signal from the main mono or stereo mixing console mix bus and amplifies all frequencies together in the desired balance. If the main sound system is stereo, the subwoofers can also be in stereo. Otherwise, a mono subwoofer channel can be derived within the crossover from a stereo mix, depending on the crossover make and model.
