As the topic says...what component set do you think are better and WHY? They will both be the same price (Also what component set would sound better for rap?)
I thought you just canceled your order for the k2's because they were too deep.... Between those two sets, i doubt you can go wrong. You'll get alot of different opinions on which you should go with. From the reviews i've read, i'd like the CDT's better than the Focal's b/c the tweeter is supposed to be more laid back. I've not heard either set though.
kind of I made a spacer out of 1.5" mdf so I have 1.5" more to work with. One question should I make the spacer the smallest possible...EX. I will have 3.5" to work with, the midrange is only 3.25" should I make it 3.25" or as small as possible or will it be fine with about .5" of extra room?
