Finalizing system ~$600
Discussion in 'General Car Audio Discussions' started by braindrift, Jul 29, 2008.
  1. braindrift
    braindrift Full Member
    WANT
    -Clean sound over loudness
    -60-70Wx4 200-250x1 at 4ohm 5 channel amp
    -accurate bass
    !!!!!!!!!!!!!!!!!!!Not sure about comp set and sub!!!!!!!!!!!!!!!!!!!
    Front
    http://sonicelectronix.com/item_7755_Focal+165+A1.html
    or
    http://sonicelectronix.com/item_10190_Memphis+15-MSYNC6.html
    or
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17540
    Rear
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17545
    Amp
    http://www.sonicelectronix.com/item_10142_MB+Quart+PAB+5400.html
    Sub
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17537
    or
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6476
    -Is amp good for what I want? (Want to keep amp power low don’t want to but a new alt.)
    -Comp set concern how should I match the sens., rear set at 88db.
    -Sub unsure probably PG.
    -Heard only PG, like.
  2. cccullen
    ok, my only complaint would be the amp and subs you picked. you may want to look at the elemental designs NINe.5 and I don't know if elemental is still having a sale on their subs but you may want to take a look at those as well.
    As for the comps Focal and the RSD's are good comps, if G3 was here he'd tell you to also look at polk. Other than that you look all set.
  3. pedro quiroga
    i would do the PG's in the front and rear. ive read good reviews on them.
    nothing wrong with the PG sub at all. i would keep it all PG if i had to do it over again.
  4. jonnyv713
    nah CC, they are history. well, if u r talkin about the D4 13Kv.2's
