Easy question: About port tuning
Discussion in 'Subwoofer Box and Custom Fabrication' started by subkiller, Aug 18, 2008.
  1. subkiller
    subkiller Full Member
  2. aznboi3644
    get a picture up of your enclosure.
    What do you mean what size port??? What kind of enclosure is it??
  3. subkiller
    I dont have a camera handy right now, but the box design is similar to the one shown here http://kollmanradio.com/images/db212.jpg
    The currnet port is a slide in made of 3/4 inch mdf, rounded edges, the port measures 7" H x 4" W x 9" D
    I am trying to find out the proper port size for a decent sounding tune.
  4. fstrfvo
    fstrfvo Full Member
    Why dont you contact MMATS and ask them for the specs that go with those speakers.
  5. subkiller
    Oh, I have the specs for the mmats. Recommended box size is 2.0 cu.ft (per speaker) but the port recommended has me confused. It recommends a port of 20 sq. inches x 15" L
    I don't know how to figure that out. Would it be 5" x 4" and 15" long?
    Could I mix it up and make a port 2" x 10" and 15"L or can I vary the dimensions with the length? The port thats in it now is 7" x 4" x 9"L
  6. Ranger SVO
    Yes and no
    The port needs to be 15-inches long, the opening can be 2-inches by 10-inches or 4-inches by 5-inches or any cross sectional area that gives us 20 inches squared.
    Now for the 7" x 4" x 9"L, We need a little more info, what frequency do they recommend the box be tuned to.
    Your box that measures 35 W x 20 H x 13 D is about 4.1 cu. ft. A 6-inch round port tuned to around 36 to 38 Hz would need to be about 9 inches long. So your 7" x 4" x 9"L, (which is similar to my 6-inch) might work if 36 to 38 Hz is the right tuning. Now my estimate assumes that your box is one large box with no divider in it.
  7. subkiller
    I should make the port the same size as they recommend. You are right in guessing that the box is a single enclosure, no divider. I forgot that the recommended port would actually need to double in size, because the specs are for one single sub. So, does that mean I need a port 10" x 8" x 30"L ? Or two ports that are 5" x 4" and 15"L. I am a tad confused, my brain just cannot wrap around this. They don't list a recommended tuning frequency for these subwoofers. I have the spec sheet for them, perhaps theres a way to figure out the proper frequency from those figures?
  8. tyrant1014
    tyrant1014 Full Member
    Listen to the ranger... he knows his stuff, because he does. :D
  9. subkiller
    I know I'm a pain in the a**, but I really need the last question answered. Do I build a port thats 30" L, or do I add two ports?:confused:
  10. Ranger SVO
    OK, lets do this. Your box that measures 35 W x 20 H x 13 D is perfect for porting. Use NO divider, both woofers should share the same air space. A single 6-inch round port 9-inches long should work. Your 7" x 4" port will also work at 9" long.
    I will post a slightly different box idea in a few minutes
  11. subkiller
    thanks ranger, how can I bring the hz down to around 34?
  12. Ranger SVO
    I really like 6-inch round ports, it works s well for many applications. The problem is finding PVC that size. Our local Lowes carries 6-inch PVC.
    A slightly smaller box would measure 13"H x 34"W x 18"D. A 6-inch round port around 10-1/2-inches long would work well. Again NO divider, both woofers should share the same space.
  13. subkiller
    sweet! time to make a plug for the current port hole, then I'm off to lowes. Thanks Ranger! Preeshiyadit.
  14. Ranger SVO
    The box would need to be larger, go with 36"W x 14"H x 18"D, Now the 6-inch diameter port would need to be about 11 to 12 inches long.
  15. aznboi3644
    Mmm....I love big ported enclosures
