door panels
Discussion in 'Subwoofer Box and Custom Fabrication' started by Moose, Mar 29, 2006.
  1. Moose
    Moose Full Member
    Is it wrong just to do part of a door panel in fiberglass for a speaker mod? Will the panel be able to support the weight or will the entire panel have to be redone?
  2. 1wykdmk8
    1wykdmk8 Adminstigator
    You can do it any way you like, and yes the door panel is strong enuf....but that all depends on what you have in mind as far as what kind of panel you plan on building.
  3. peter_euro
    peter_euro Full Member
    do whatever looks good to you... not a matter of panel supporting anything as much as panel being attached to rigid surface that should be your concern...;)
  4. Moose
    Moose Full Member
    that was the point of the question, whether or not only doing half the door would provide enough support
  5. peter_euro
    if you attach the half to the door sheetmetal, yes, no reason not to...
