Irving's audio system can't play music. It's designed to play a single frequency -- 74 Hz -- very loud. Irving, you see, is a dB drag racer. http://www.cnn.com/2003/TECH/ptech/07/02/popsci.stereo.kill/index.html
Seems like a lot of waste, all those amps speakers and it's only designed to make a single frequency noise. Fill the doors with cement, you can't drive the car? What the hell good is it lol.
Top Fuel drag cars are only made to to go really fast in a straight line, and get like 1/10 miles per gallon...what good are they to drive on the street than
Yeah...its crazy. I saw on trucks they had one of the injectors for a top fueler in a demonstration plexi box thingy...and they showed you how much fuel these injectors would pump out and OH MY GOD at idle it is like turning on your shower and when they showed you what it looked like at full throttle...looked like my dads 3600PSI pressure washer
Yea it does impress me, but like, I like loudness but damn, that seems like a waste. He probably dosen't even get to half way loud when he bumps.
Um...those vehicles aren't meant for people to be in them when they compete. You'd lose your hearing and possible die being in the Pioneer truck lol
i did have a question though about DB drag. I was checking rules and so forth. The Street A class is what I was interested in. It never said anything about wattage limits? Just says woofer amp and battery limits.
Found a cool site, the info your looking for must be here: I wouldn't think there would be wattage limits but what do i know lol. http://www.dbdragracing.com/dbdrag/rules/index.asp?Page=1 Street Division · Street A Class – A maximum of 1 subwoofer amplifier (or 2 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 2 electrical conductors may be used to connect the amplifier(s) to the woofer(s). (Please see the definitions section for more detail regarding conductors.) o One 12-inch woofer o OR a maximum of two 10-inch woofers o OR a maximum of three 8-inch woofers · Street B Class – A maximum of 2 subwoofer amplifiers (or 4 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 4 electrical conductors may be used to connect the amplifier(s) to the woofer(s). o One 15-inch woofer o OR a maximum of two 12-inch woofers o OR a maximum of three 10-inch woofers o OR a maximum of four 8-inch woofers · Street C Class – A maximum of 4 subwoofer amplifiers (or 8 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 8 electrical conductors may be used to connect the amplifier(s) to the woofer(s). o One 18-inch woofer o OR a maximum of two 15-inch woofers o OR a maximum of four 12-inch woofers o OR a maximum of six 10-inch woofers o OR a maximum of eight 8-inch woofers
Is this the truck azn? http://www.pioneerelectronics.com/pna/printer/friendly/0,,2076_4057_56825958,00.html?compName=PIO_ArticleComponent&printComp=PIO_ArticleComponent&
That's not bad... lol I guess i wouldn't mind doing something like that if i ever have the money to do it but it has to be driveable and play music for it to be worth it to me. It is interesting though. 72 16-volt Turbo Start batteries and three Ohio Generator 285-amp alternators and produces 115,200 watts of power.
Well if you had something that could play actual music and be daily driveable it wouldn't be anywhere close to even touching the world record
are you sure about that, what if we didn't use speakers for bass..or to vibrate the compressed air or vacuum. http://micro.magnet.fsu.edu/electromag/java/speaker/index.html
you must open your mind lol, what if i found something that can do the same thing as a woofer but without the restrictions of a speaker, ten million batteries and amps. I know about cement filled doors, bracing throughout the truck so it doesn't rip itself apart from the pressure, to gain an extra 3db you must double your amp power. Are these the reasons you say no? Cough up all your info lol.
Sound Is Energy Energy In The Air: How Sound Is Made CRASH! BANG! Did you hear that sound? It was made by air vibrating. The same is true for sounds made by musical instruments. The difference between NOISE and MUSIC is that musical sounds are organized into patterns that have pitch and rhythm. Noise is just random, disorganized sounds. Sounds are made and travel in the same way whether they are musical sounds or noise. A musical sound is called a tone, and is produced by air vibrating a certain number of times per second. These vibrations are called waves. These sound waves must be contained in some way so that the performer can control the loudness, quality of the tone, and how long it plays. Most musical instruments have a reed, a string, or some other device that creates sound waves when moved. Sounds are different because of harmonics, which are higher and quieter sounds mixed in. They are not heard separately, but add to the tone of the sound, making an oboe sound different from a trumpet or drum. The number of times that a sound wave vibrates in a second is called its frequency. Scientists even have a name for how they measure the frequency of sounds. They measure it in cycles and call it hertz. High notes have a higher frequency than lower notes and this changes their shape. Different types of sound waves have different shapes. Notice that even if pitch and volume change, the shape of the sound wave stays the same. Some instruments produce sound when blown into. For the brass instruments, the vibration of the player’s lips make the column of air vibrate. Most woodwinds have a reed, which vibrates when the player blows on it, making the column of air vibrate. Sound is produced from the flute when the player blows across the mouthpiece, causing vibration of the column. This image shows how the sound waves of different instruments might look. PROJECT: Wrap some stiff tissue paper around a comb. Hum on the paper and feel the vibration as it shivers. OR, tape some paper tightly over one end of a cardboard tube. Sing into the tube, gently touching the paper. Can you feel the vibrations? Try making your voice higher or lower, and notice the different types of vibrations. The string section of the orchestra, such as the cello, violin and harp, produce sound when one or more of their strings vibrate. The vibrating strings then cause part of the instrument to vibrate, putting the surrounding air in motion. The strings of cellos and violins are usually stroked with a bow. With some instruments the strings are plucked, such as the harp or guitar. PROJECT: Wrap a rubber band around your fingers. Pluck it a few times. Can you see and feel the vibrations? The harder you pluck the rubber band, the more it will vibrate, creating a louder sound. If you stretch the rubber band, making it longer and thinner, what do you hear? (It will be a higher pitch.) Other instruments produce sounds when struck, banged, shook or scraped. When the membrane (the stretched part) of a drum is hit, it vibrates and creates a sound. Instruments such as the xylophone or chimes, have a series of tubes or bars. When you strike one of the tubes or bars, a sound is produced. PROJECT: Tap an empty metal tin with a spoon. Feel it vibrate as it makes a sound. This is similar to playing a triangle. Fill an empty glass jar with water almost to the top. Take a pencil, and gently tap it near the rim. Fill other jars with different amounts of water in them. Do the jars sound differently? The more water in the jar, the lower the pitch, because the vibrations are slower.
