Can anyone tell me what wires are what here?
Discussion in 'Car Audio Head Units' started by tonester, Dec 1, 2006.
  1. tonester
    tonester Full Member
    I have a 1984 toyota celica gts and i have a cheap sony explode deck in there , i hooked it up so the unit "plays" cd's and basically works fine exept i dont know what wires coming from my car are the speaker wires? can you please take a look at the pics and tell me what pairs are the speakers? thankyou,(need music badd)
  2. DaveDSMer
    DaveDSMer Full Member
    let me see what I can find.. on a side note, if you want to know what color are the speaker wires you can look at the actual speaker and check what color wires are connected to it then reference that back to the harness there and see if there is a match.. pay close attention which is negative and which is positive... but ill see if i can find a diagram to help out.
  3. DaveDSMer
  4. tonester
    thankyou very much for taking the time to reply my question :D :D :D :D :D :D :D :) :) :) :)
  5. Hautewheeler
    Hautewheeler Full Member
    sometimes chasing wires isn't so easy because some manufacturers switch colors at junctions (plugs). study the diagram that Dave gave you, that should help out a lot, but by the looks of it, some of that wiring may not be original, when you're confident that you have the wires identified, be sure you test them all (all channels) to make sure that you have them all connected right before you tie everything up and stuff it back in the hole.. use of the balance and fader controls will be essential in determining that everything is correct.
    good luck and have fun!
