i have 2 15in subs and one 1600 pyle dryver amp.. do i need another?? and if so.. does it have to be the same wattage or even the same brand?:
are they up and playing? if you feel you need another amp for your sub then get it,but it has to be the same wattage. preferably the same amp
Pyle dryver PLAD-214 2-Channel 1600 watts 2 x 250W rms at 4 ohms 2 x 800W max at 4 ohms 1 x 900W max at 4 ohms bridged 2 x 400W rms at 2 ohms Remote bass level control Electronic crossover network Tri-mode capable Gold-plated RCA inputs High/low pass filter controls 8 5/8" W x 2 3/4" H x 9 13/16" D
Diecast Aluminum Frame (patented large excursion, high dissipation frame) Triple-Stacked Magnet Sealed-Box Enclosure Continuous Power Handling: 3,000W Music Power Handling: 5,000W each do you need more info??
someone correct me if im wrong but for the specs on hose subs you need much more power than what you have.
ok then.sounds like you do want another amp.or at least one amp big enough to power both subs. whats your budget?and also is your cars electrical set up to handle one huge asss amp?
yea your right, my budget is about $120- 250 but im already have electrical issue with one amp so should spend a little less on the amp an get and extra battery too?
after riding around playin my subs for a while and i park it and leave in the garage for a few days and i would go to start and i wouldn ever start without a jump
you probably have a bad battery...i would put a second battery in anyways because you'll have a lot of power.
i would recomend an optima batt or any gel battery cause the wont leak i dont have an optima in my car right now but my brother sells em at his shop and he says they are the best.
