well I got into some sh!t this past weekend so I need to sell pretty much 75% of my inventory...I'll get pics up tomorrow. Prices are negotiable...I need to get $450 asap. (1) Elemental Designs Nine.1 Mono Amplifier - $250 shipped -1200 watts rms @ 1 ohm @ 12.5 volts -900 watts rms @ 2 ohms @ 12.5 volts -450 watts rms @ 4 ohms @ 12.5 volts (2) Memphis PR15 15" subwoofer (Newest Version) - $80 shipped 250 watts rms (takes 400 watts all day long) Dual 4 ohm Voice Coils -(3) Lanzar 2 Channel Amplifier - $35 plus shipping Rated at 600 watts MAX Realistically the amp will put out -50 watts rms @ 2 ohms per channel -25 watts rms @ 4 ohms per channel (4) Two 10" MTX subwoofers - $25 each plus shipping or $65 shipped Came from an older model of the tri-loaded sealed enclosure I'd say 100 watts rms per sub. I used to have all three in the sealed enclosure giving the tri 400 watts rms all day no sweat. I was planning on using these for the test rear loading horn enclosure (5) Profile Mono Amp - $75 shipped 400 watts rms @ 2 ohms 200 watts rms @ 4 ohms (6) Cerwin Vega 150.2 Amplifier - $50 shipped 150 watts rms per channel @ 2 ohms 75 watts rms per channel @ 4 ohms (7) Single 12" Ported Enclosure - $50 plus shipping - 2.5 cubic ft tuned to 30Hz with a single 4" round port(I'll have to recalculate tomorrow it may be 35Hz) - I used to run my old school JL 12W6 in this enclosure...response was deep and accurate with a very flat response. No port noise with 400 watts rms. Here is the specs of the sub...build pics can be seen in my thread (8) EHQS 12" Subwoofer - $15 plus shipping T/S parameters: Qts: .375 Qes: 0.49 Qms: 1.506 Fs: 25 Hz Re: 1.8 Vas: 157 L MMS: 90g BL: 7.2 Tm SPL: 89.1 dB SD: 510 M^2 Xmax: 9.1 MM Magnet Width: 5.25" Cutout: 11.00" Mounting Depth: 5.00" Total Height: 5.60" Displacement: .04 cF Outside Diameter: 12.00" Box Size: 1.5cF Sealed / 2.0cF Vented Power Handling: 200w (9) Pair of used Kenwood 6x8 Coax Speakers - $40 shipped 35 watts rms...crossed over at 80-100Hz can take 70 watts all day 4 ohms (10) Single 12" Transmission Line Enclosure - $50 plus shipping Here is the specs of the enclosure...build pics can be seen in my thread (11) Dual 10" Sealed Subwoofer Enclosure - $25 plus shipping - 0.7 cu ft per chamber Thats all I can think of off the top of my head for now...more updates tomorrow
damn azn, getting rid of almost everything? that's sucks man. hope everything is ok..... whoever is looking for an amp. jump on this NINe.1. it's a sweet amp.
will it also go .5Ohm? nevermind. answered my own question. http://www.youtube.com/watch?v=ljF1r00tGIg u think i can build a box thats better than that one?
around 14.4 volts these amps have been benched between 1500-1600 watts rms. Competitors have burped this amp at .25 ohms before with a stout electrical. what box are you talking about??
the 4 13kv.2's. i am gonna run dual 100 amp alts and a second battery. do u think i can do .5 oms daily?
u dont think it can handle it? idk if it would be enough power at 2Ohms. maybe i can switch between the 2 when i wanna show off a bit.
I'm not sure if it can handle it daily...It probably can but at low volume levels...no way the amp can handle all day wanging at .5 ohms. 1 ohm it can pump all day no sweat.
