Any one got mono 2 channel amp ????
Discussion in 'Car Audio Classifieds' started by no1vdub, Jul 13, 2011.
  1. no1vdub
    no1vdub Full Member
  2. shriver187
    shriver187 Full Member
    a mono is a 1 channel bro.... you have paypal? text me and ill get u squared away.. 507-384-8034
  3. no1vdub
    no1vdub Full Member
    oryt lol can you run two 12"'s off one channel ? and yeah I have paypal mate
  4. shriver187
    yes... u can run 2 12's off 1 channel.. see typically amps that are 1 channel or mono blocks are made specifically to run subs... do u know what ohms the subs are by chance?
  5. shriver187
    nevermind i found it.. they are single 4 ohm coils... and may i ask where u are located? cuz shipping will be more expensive if u are out of the states..
  6. no1vdub
    no1vdub Full Member
    thanks you been a big help, I'm from the u.k
  7. shriver187
    ya im not sure how much shipping would be to the u.k if u were to buy an amp from me.. i mean i could check. but u might be better off just buying something closer to u. so try to find a monoblock amp that puts out around 1000 watts prolly.. u can turn the gains down on it.. its always good to go with a bigger amp then u need cuz it will provide cleaner power for your subs and in return ur subs should last longer..
  8. no1vdub
    no1vdub Full Member
    thanks mate, i have a look and if i can get bigger than a 1000 watt is it better and do i need to look at the rms and stuff ?
  9. shriver187
    yes i would always go by rms.. not by peak... u dont need bigger then 1000 but if the price is right u can always turn the settings down...
  10. no1vdub
    no1vdub Full Member
    ok thanks jkkkkkkk
  11. TheViking
    dont know the conversion from pounds to us dollars...but in my opinion....i would steer clear of that amp. An honest 500 watt amp will outperform a "cheesy" 3000 watt amp everysay....
  12. 6.5ldiesel
    6.5ldiesel Full Member
    I have a RF T20001BD amp, does 2400RMS at 1 ohm
    For sale
  13. shriver187
    yes dont buy that amp.. a good amp is gonna cost a little more.. diesel he is in the uk.. i imagine shipping would be insane...
  14. no1vdub
    no1vdub Full Member
    will a Power Acoustik PS1-3000D Car AMP 1700 Watt Mono CLASS D run the subs good ??
  15. no1vdub
    no1vdub Full Member
    this is how i have my to 12" hertz sub wired up is that ok ???
  16. shriver187
    it doesnt show how u have them wired
  17. no1vdub
    no1vdub Full Member
    pppppppppppppppppp
  18. shriver187
    u dont need to wire it like that.. u can wire all the voicecoils directly to the amp.. it is 1 ohm stable
  19. subpounder101
    subpounder101 Full Member
    the only thing with boss, watch the fuses. If thats a 1200 and only has two 60A and is not a digital amp. Well 60Ax12V=720W
  20. no1vdub
    no1vdub Full Member
    can you find out a shipping price and a cost of one of these amps please
