Well I got a Viper 5900 installed in my car (didn't have remote start installed), and the siren is out in the open attached to the fenderwall. I think I need to relocate that siren and add at least one backup siren and battery. How many can/should I get of each? Where are good places to hide them? And where can I get these for cheap (preferably not ebay)? Thanks a lot
One under the rear of the car, that should work fine...... Of course...many other options are available... You can install as many sirens as you want if you use the proper relays ....
my friend who used to work at Best Buy installed 8 different sirens INSIDE his car hidden behind the vents. They were wired so they would fire off sequentually one after another. He said it was so loud that it made their ears bleed lol
haha yeah...eventually he told me he took out 4 of them and left only 4...but still four sirens prolly a few feet away from your face blasting full volume must still be pretty loud
When I looked up my alarm online it said... 6 channel remote start/security/keyless entry system 1 mile range with Spread Spectrum Technology (SST) Confirms commands and system triggers on the transceiver LCD screen Clone-Safe® Code-Hopping® Parking Light Flash Failsafe® Starter Kill Anti-Grind Stinger® DoubleGuard® Shock Sensor Revenger® Six-Tone Siren Bright Blue LED Status Indicator Miniature XCRS (Extreme Capacity Relay Satellite) Defroster Output Built-in Turbo Timer Dome Light Supervision Comfort Closure 4 Auxiliary Outputs Horn Honk Includes One 2-way Responder Transceiver Does that mean I can hookup 4 sirens?
Aux Outputs are usually for other things like window roll up modules or other add ons. Aux Outputs were not intended for sirens
Hook up your alarms (+) siren output to pin 86 on the relay. The second relay is optional. It will honk the horn. I use this set up in my truck. I have 2 sirens and the horn. Its annoying. Also use different brands of multi tone and single tone for a super annoying affect.
but you would also need an air compressor and an air tank...you got room in the ranger for that, ranger??
Its still a dream, but anything I put in like that would have to go under the bed. But if I found something like that at the right price I would make it work.
