So I bought this amp and these speakers. Boston Acoustics GT-275 and Boston Acoustics SX50. I have cut holes in my door to add these speakers but I want 6 speakers so I'm keeping my other four. My question is about getting the RCA jacks to the amp. Do I go and get some Y connectors and will this split the front signal in half or will it be the whole thing? If I am getting only half the signal is there a way to get the whole thing? Thanks in advance.
i was also wondering the same thing..but are you adding another amp for the 2 speakers you are adding?
Ya, new amp with the speakers so its like one 4 channel and the new 2 channel. But I thought I heard that it divides the signal to the amp if you use a Y cable.
how many pre outs does your stereo have? if it has 3 preouts then you could always use the rears if the front pre outs are taken up...
It has 1 set for front, rear and subs. But on my other speaker amp it has a set of outputs that I haven't really been sure what they are for. They are only labeled as "RCA Output Jack".
use the splitter. thats what i did to mine before. now im running the front stage using my front and rear outs. no more rear fill. or...does your 4CH have a pass thru?
