ok right now i have a 10" pioneer sub in behind the seets runnin off the hu with no amp and ya it sucks so i wanna built 2 boxes and put them under the seats and the amp under the center consel. i was wondering if i should use 8's or 10's i dont have alot of air space available. and i dont wanna spend alot i was thinkin about this equipment 2 Parts Express:Coustic US-CX10-04 10" Subwoofer 1 Power Acoustik OV2-600 - 4 ohms: 95 watts x 2 • 2 ohms: 120 watts x 2 • Bridged, 4 ohms: 240 watts x 1 • PWM MOSFET power supply • Tri-Mode capable • 3-way protection circuit • 4 gauge power/ground connectors - , Car Amplifiers, 2-Channel Amps - Soni
ok i have just decided that the racecar can wait for another year while i get the truck thats gonna pull it ready and get a system in it and the new bike i want is gettting to be out of the question and all the money i get is goin into the truck which isnt alot because i dont really have a job right now but ya just give me suggestions on this and ill go from there
r these good subs? Hifonics HFi 12D4 - 12” HFi Series Subwoofer • 600W Max • 300W RMS • Injected Poly Light Rigid Cone • 1” NBR Reinforced Rubber Surround • Dual 4 ohm High-Temp KSV Voice Coils • Heat Dispersing Ported Back Plate • High Strength ABS Motor Cover - , Com
oh man! what about getting some of those ED 12in subs for behind the seat. or an amp for the sub you all ready have.
i have like no room back there cause i wanna keep the back for storage. it is not an extended cab. and i dont think i want an amp for the sub i have. but idk if they r really any good i have two of them, but i only have one in a truck box behind the passenger seat.i would really like to come up wit a design for under the seats, i will take measurements tomorrow under them. should i take some pics of all this so we can get an idea. and i would like to spend about 150- maybe 200 if i go any higher i will have to wait even longer
well if money is tight then maybe some 6.5's.they are small.and like 4 will sound pretty good in the right box,and they wont need a ton of power. maybe 50-75 watts each.http://www.realmofexcursion.com/videos/TangBand/6.5.1.wmv or the 8's...http://www.realmofexcursion.com/videos/TangBand/w8740c.3.wmv
Since you said 8", the other day I was at a local Memphis dealer, I swear I heard the best 8" sub in the world. Memphis Power Reference or something rather. The amp that was hooked up to it also had 4 speakers hooked up to it. The sub was 200 watts max, 100 watts RMS. It left us shaking. They look similar to like I said one 8" was hittin hard.
MEMPHIS CAR AUDIO 15-MS84D 8" SUB WOOFER SUBWOOFER NEW - (eBay item 250196099449 end time Dec-15-07 10:05:42 PST) its 50 on ebay
which one of those would be good and i think i will start with two for now should i build the enclosures about .75 each tuned to about 35hz each with a 2in port about 7.5in long
Parts Express:6-1/2" Hand Treated Paper Cone Woofer i found these too i thought i might buy 4 or six cause they only need .25 cubes
Power Acoustik PS2-420 - 4 ohms: 80 watts x 2 • 2 ohms: 95 watts x 2 • Bridged, 4 ohms: 190 watts x 4 • PWM MOSFET power supply • High or low level inputs with floating ground • Tri-mode capable • Includes remote level control knob • Frequency Respon with maybe this powerin them
these wont do crap for bass unless you have a bigger enclosure than .25 cubes. They are not subwoofers...they are midbass speakers. If you are limited on space I would recommend the Elemental Designs SQ10. I just built a .4 cu ft sealed box for one for a customer and it sounds really nice...really tight and digs deep too. Elemental Designs If you want to go the mulitple 6.5 sub route go with either of these. Parts Express:Tang Band W6-1139SI 6-1/2" Subwoofer as for an amp could you spend a little more than get some headroom for power. Power Acoustik PS2-800 - 4 ohms: 150 watts x 2 • 2 ohms: 180 watts x 2 • Bridged, 4 ohms: 360 watts x 1 • PWM MOSFET power supply • High or low level inputs with floating ground • Tri-mode capable • Includes remote level control knob • Frequency Resp
or could i just see what i can build a enclosure about 1.5 cubes and use that PA 420 amp with this Parts Express:Coustic US-CX10-04 10" Subwoofer or Rockford Fosgate Punch P212S4 - 12" Punch Stage 2 Single 4 ohms Subwoofer • 250W RMS • 500W Peak • aluminum voice coil former • large roll surround • stamped CRS basket • linear spider • double stacked magnet motor assembly • sensitivity: 86dB - , Co or MB Quart Discus DWH 304 - 12" Discus Series Dual 4 Ohms Subwoofer • 600W Max • 300W RMS • Injection molded polypropylene cone woofer • Nitrile butadiene rubber (NBR) surround • Finite element analysis linear flux saturated magnetic plates with chrome
or this one Alpine SWE-1042 - 750 Watts Peak Power Handling / 250 Watts RMS • Frequency Response : 32Hz - 1kHz • Sensitivity : 87 dB • 44.8 oz Magnet - , Component Subwoofers, 12" Component Subwoofers - Sonic Electronix i was also lookin at a boston G1, why does that only handle 200 watts max
ok i think i decided on this combo Rockford Fosgate Punch P1S412 - Power Handling: Peak: 300 watts / RMS: 150 watts • Parabolic injection molded ABS/Acrylic dustcap • Linear spider with embedded 16 AWG tinsel leads • Frequency Response: 26-250 Hz - , Component Subwoofers, 12" Componen and Power Acoustik SL2-340 - 340W Peak 2-Channel Amplifier • 70W x 2 chan. @ 4 Ohms • 85W x 2 chan @ 2 Ohms • PWM MOSFET power supply • RCA input/output • dual color indicator LED • protection circuitry • phantom channel - , Car Amplifiers, 2-Channel Amp
