6 ohm speaker to a 4 ohm rated amplifier
Discussion in 'Car Stereo Amplifiers' started by subujoseph, Apr 23, 2012.
  1. subujoseph
    subujoseph New Member
    I know this is a car audio forum, but excuse me if this is the wrong place to ask this question.
    I have a pioneer sx-x360 5.1 system. the impedance of the amplifier(receiver) is 4 ohms. my question is, can i connect a 6 ohm impedance speaker to this amplifier? will this blow out the amp or speaker?
    thanks in advance.
  2. wingless
    wingless Full Member
    Yes, the manual for the SX-X360 lists the amplifier specifications as: RMS Power Output / 100W per channel / 10% T.H.D. / 4 Ohm.
    The usage of a 6 Ohm speaker will limit the amplifier to provide less power to the speaker, but will not damage the amplifier.
  3. subujoseph
    thanks wingless
    I am trying to understand this, if you have an amplifier with 4 Ohm specification, am I right to conclude that connecting any speaker with impedance greater than 4 Ohm i.e 6 or 8 Ohm will not damage the amplifier, and if the amplifier specification is say for e.g. 8 Ohms, connecting a speaker with lower impedance such as 4 Ohms or 6 Ohms will damage the amplifier?
    Once again thanks for the reply.
  4. wingless
    The specification section of that manual is poorly written.
    A properly written manual will list the minimum acceptable impedance for the amplifier. A larger impedance (Ohms) is okay, less than the minimum is not okay.
    The 6 Ohm speaker connected to your amplifier is okay. It will probably have less volume than the 4 Ohm speaker, but won't hurt the amplifier.
