ok im going to be installing every thing soon.... so far i did the big 3 with 180 amp alt- with 1/0 cable. im running 2 12'' fi audio btl at 2500 watts a sub @ 1 ohm on a atomic 5000.1 amp is my alt big enough to do this ?? what kind of cap and battery should i look into picking up? and what else do i can do to make every thing cool? thanks!
180 amp alt is nowhere near big enough for 4000-5000 watts. You should get atleast a 250 amp alternator or higher. You spend so much money on the subs and amp but you should not skimp on the power supply. Even with a 250 amp alternator you will probably need two extra group 31 batteries.
ok so where can i find a alt big enough... for a 95' Toyota Avalon xls??? if you can send a link that would be cool.
check High Output Alternator Hi Amp by HO , iraggi alt, Excessive Amperage - High output alternators by C.S.A. , Home
ok i run 2 180 amp alts.... would that be enough? that would be like 360... would i still need to go big on the 2 battery's? powermaster d3100 or two kinetik 2400???
i would add atleast 2 kinetik or powermaster to be on the safeside since youll be running it daily you need large reserve capacity since it ill be 5kwrms
Nice system! I'm jealous lol. A high power alternator or two is more important than the batteries. I would do that first then see.
lol those multicell have enough juice to powerup my whole neighborhood lol i dont think that you can use them daily they are sticktly spl batt. and for the price you can put bout 4 powermasters
thanks!! it took some time to work every thing out.i found this one guy on a board to make me a custom box for the 2 btl's..... its got black carpet on the sides and on the back of the box. the top of the box is panted shinny black with a big shinny white fi logo and the front of the box and slot port is shinny black it should look pretty cool. i just told him what i wanted it to look like!! it only cost me $200 and $66 to ship.. awesome guy,knows every thing there is to know about making sub boxes. he has been doing it for 18 years. il post some pics of the box when i get it. It should be here Monday.
he was useing 2 FI 12's. he said he can play music,but the amp has to be turned way down along with the bass
he would burp it then keep the car running to charge it for later. he would let it idle for 10-15 mins then walk around. he was judged at least 4 times that day plus port wars.wich he won with a 166.6 or something.in only 1 port.at 5000 watts. you are also aloud to have your car running while being judged
god thats a 10,000 watt amp and some nice subs do you got anymore pics?? what is the max wattage on a 12'' fully loaded btl ? on the web site 10'' 12'' 15'' 18'' all say 2,000 watts rms ?
Enclosure is a HUGE factor is how much power it can handle...yeah the BTL can handle 3000 watts but not just in any enclosure.
