18 inches of thunder
Discussion in 'Car Subwoofers' started by aznboi3644, Jun 9, 2007.
  1. aznboi3644
    well just ordered an Elemental Designs 19Ov.2 sub...dual 2 ohm of course to get 1200 watts of fury from my Nine.1.
    Mmm...10hz sounds delicious already
  2. TheViking
    10 Hz dont sound good, it FEELS good!!!!!! LOL!!!!
    Too bad our cars wont accuratly reproduce those lower registers with any reall authority!
    Tell ya waht, put that SOB in the right box and it will rock your world....
    I have never had a problem with large drivers, they are as tight and fast as an 8 in my book.....just look at all the pro sound equipment that uses large drivers, the tightness of the bass will knock you in the chest harder than a pro boxer.
    post a link to what you are getting, i am curious....
  3. pedro quiroga
    sweeeeeeeeeeeeet!pics when its in.and a vid.
  4. aznboi3644
    vids will be on the top list...as will be a work log for the box building and such
    well the eD guy over on the eD forums said this sub will have authority even at 10Hz...well at lot more authority than other setups
  5. gustov
    gustov Full Member
    dont put ya face in front of it
  6. electrolytic
    electrolytic Full Member
    hmm, nice! Any specs? I don't see any at ED
  7. aznboi3644
    Qts: .369
    Qes: .37
    Qms: 7.5
    Fs: 26 Hz
    Re: 3.5
    Vas: 228 L
    Mms: 307 g
    Bl: 22.1 T*m
    SPL: 90.5 dB
    Sd: 1200 cm^2
    Xmax: 22 mm
    Voice Coil: 62.5 mm
    Magnet Width: 8.200"
    Cutout Diameter: 16.375"
    Mounting Depth: 9.625"
    Weight: 42 lb
    Total Height: 10.600"
    Displacement: .10 ft^3
    Outside Diameter: 18.375"
  8. electrolytic
    Nice! Thanks, i'll run it through bassbox.
  9. aznboi3644
    lol as you do everything now...make sure you enter the parameters in correctly this time
  10. electrolytic
    yes, parallel right?
  11. aznboi3644
    indeed parallel
  12. electrolytic
    I can't get the db to go up to +6db but everything else looks ok, maybe i have something wrong.
  13. electrolytic
  14. electrolytic
  15. electrolytic
  16. aznboi3644
    no need to get the peak up 6db.
    my daily ported box will be 6 cu ft tuned to 35hz with two 6 inch round ports...using a 1 inch round over bit to make it a flared port
    for a fart box i could make a 8 cu ft box tuned to 47Hz with three 8 inch round ports lol...i have enough room if need be
    Pink line is fart box and Yellow line is daily
  17. aznboi3644
    My sub should be here by tomorrow!!! WOOT WOOT
    for ground shipping three days is fuking fast
  18. pedro quiroga
    how soon before you have your box made?or is it done?
    man i cant wait to see it in action.
  19. aznboi3644
    havent started on the box yet...can't work until doctor said its okay for me to work...don't wanna rip my finger apart.
    You can't wait?? Hell I can't wait.
    I'll make some vids for sure...and lots of pics
    tomorrow though i get up and go to the doctor to get my finger checked out at 11 AM...then I have a physical at 1 PM...then lunch with the girlfriend...then back home and seeing the monster
  20. pedro quiroga
    you dont need to use THAT finger to work do you?:cool:
    joking....:lol:
