I need some answers.
Discussion in 'General Car Audio Discussions' started by SoloX531, Aug 23, 2011.
  1. SoloX531
    SoloX531 Full Member
    How do I know If I need the big 3 upgrade? I think thats my problem.
  2. TheViking
    TheViking Well-Known Member
    Amp getting hot.....lights dimming....and especially if you notice batterry voltage low when doin the boom thing... i am not sayin it will stop your issues, but it will enable your electrical system to do ALL it can.....next thing would be a bigger alternator or a \nother battery....or both...and also, limit your volume...a stock electrical sytem can only do so much!
  3. SoloX531
    Lights dimming...check. Hot amp...not so much. I talked to someone from kicker today about one of my subs, it has been making a weird noise. I mentioned to him over-excursion (because thats what I Think it is). He said "could be" then he forgot all about it and mentioned to me the big 3. This noise does increase as the volume goes up. I can't figure it out.
  4. shriver187
    shriver187 Full Member
    sounds like a scratchy coil about to go out to me... :(
  5. pedro quiroga
    could be...
    solo, can you describe the noise to us.
  6. shriver187
    i say scratchy coil cuz it does it at low volumes and gets louder with volume increase.. a sub going past its limits will usually only make noise at very high volume.. and will make a clapping sound kinda when it bottoms out.. if it makes the noise all the time its prolly a coil.. sometimes an enclosure will fall apart and make noises too though..
