solo x is finally mine!!!
Discussion in 'General Car Audio Discussions' started by manutdfan7, Jan 15, 2011.
  1. morespl
    morespl Full Member
    well theres nothing wrong living in a small town
    but heres the kicker book for a 12 solo x in the book none of there design permit any thing over 2500 watts max power so remember this when buying a amp but I was running a 18 solo x On my 6500d at .5 ohm before impedance rise and it really didn't get loud till I ran it to its limits. So me running it will be different from you running it because you will have a different car different amp the sub could be facing different.I tell you a quik story I had my 2009 t3 tsns 15 in a 6 cubed box gross tuned to 37 hertz sub back port back on my ss 6500d in a 03 impala.I sold the sub to my my buddy he ran it in a 2007 honda civic in a small box 5 cubes gross on a audioque 2200d sub up port back. His car is audibly louder then my car was with less power and a smaller box.So if you take anything from this it should be design and vehicle trumps power and equipment.
    http://www.kicker.com/sites/default/files/2007 SoloX 10-12 Sub g01 Web.pdf
  2. pedro quiroga
    this^^
    just because the sub says it can handle 2500 watts doesn't mean you NEED to run all that power.
    you said you have a good batt under the hood, and a good batt or two for the back.
    im telling you, when you run ass tons of power in a car you will run into some sort of issues.
    im betting you that in the right box for the car and sub. a 1500 watt amp will be way more than enough, and well within your current budget.
    that 0 gauge you want will not be cheap. keep the 4 gauge and run slightly less power and have an everyday street jammer.
    i demoed my truck at a show today and kids thinking you NEED thousands of watts were blown away when i told them " nope, its only about 900 rms maybe less due to impedance rise". .... " nope just regular car audio speakers, not pro audio,..... yes only 300 to 8 speakers"
    if done right, even modest power and plan of attack is all you need. that and good speaker placement. lol.
  3. morespl
    morespl Full Member
    yeah
    Just because I'm running a soundstream xxx 6500d and get crazy subs doesn't mean I couldn't get louder if I designed my system different. The gain for all the money I spent is in my opinion not worth it.If I could go back I would have did something different. But I'll tell its been a fun ride going through so many different pieces of equipment that you can't remember and seeing what most he subs on the market can do.But its also been and expensive process.You would be surprised that most the money I spent was not on the equipment in my car it was the power supply the dynamat the wood for multiple boxes the wires.I'm at $1250 in just wire and dynamat plus wood sub amps headunit line driver gm converter. Its crazy
  4. manutdfan7
    manutdfan7 Full Member
    okay so i got going on now i have a change up on the amp i got it real cheap so i didnt turn it down... its a 600.1 viper bridgeable (which i did) at 1 ohm and i also hooked up a 5 farad capacitor with a volt/amp meeter on it... so for right now i think im going to stick with the amp i have till i get more money or if you guys think that is good enough an i should leave well enough alone that i might just do that as well... is there any other tips with the the new equipment?
  5. manutdfan7
  6. connerray2010
    connerray2010 Full Member
    arguing my case lol. the ap30001d is 1ohm stable that is if you do not bridge it. the amp puts out 1500x2 at 1ohm (not bridged)and 3000x1 at 2ohms(bridged), i have the book.
  7. manutdfan7
    lmao rite... an that amp looks pretty beast, a good bang for the buck.
    but i think that cap killed my battery or my alt not sure which but pretty sure it was the alt (which i was goin to replace anyways) cause when i tried to jump it with a spare battery it didnt even give one lil crank whats so ever then tried usin the car thinkin my spare might be dead... same thing... absolutely nothin
  8. pedro quiroga
    pretty sure a cap can't kill a battery.
  9. connerray2010
    thought they were to save your battery?
  10. manutdfan7
  11. tommy2tone
    tommy2tone Full Member
    Are your terminals on the battery clean?
    I'm sure there's a autozone os advanced auto in your area,so get it jumped and take it and have your electrical and charging system checked out.
  12. manutdfan7
    thats the prob lol i cant jump the dam thing tommorw im taking out the ol battery an putin my new one in an see wat happens
  13. connerray2010
    I would go strait to one of the two parts store he listed and have them check it out. I'm sure you had this in mind any way.
