Port locations
Discussion in 'Subwoofer Box and Custom Fabrication' started by xlaudio, May 19, 2009.
  1. xlaudio
    xlaudio Full Member
    I have a sealed box that i made that i have installed already but now i want to port it, were is the best location to put a port side , front back ???? I want to use a 2nich port
    the mtx subs are a 34 frequency
    in a 1.7 cuft enclosure each side
    dual box 2 mtx 8500 dual 4 briage in 2 ohm each
    thanks
  2. aznboi3644
    2" round port is not enough port area.
  3. xlaudio
    xlaudio Full Member
    based on some port program and the size of the box they said 2'' was ok and the length of the port gets longer with a big size like 3 or 4
    so sound good bass from a 2inch port, what size shouldi go to???
  4. xlaudio
    xlaudio Full Member
    or even bigger? size port
  5. xlaudio
    xlaudio Full Member
    my box is 36.25 w
    14height
    17depth
    2 dual 12inch mtx 8500 and devided inside.
    like 1.7 each chamber
    want to port each chamber on the side the sub are at a 34freg
  6. xlaudio
    xlaudio Full Member
    sorry it is 34.5 wide
  7. aznboi3644
    You will have port noise with a 2" port. That program you used is crap if it suggested a 2" port. I would only use a 2" port with a 6.5" subwoofer.
    I would suggest a 4" round port. The problem is the length will have to be very long and folded inside the enclosure and take up that 1.7 cu ft.
    That is the problem with trying to ghetto rig a sealed enclosure to a ported enclosure. Its not easy.
    It is much easier and the end result will but MUCH better by building a ported enclosure.
  8. xlaudio
    xlaudio Full Member
    you are right i spoke with mtx and they said need 2.0 to make it ported, don't have that much room in a lincoln mark vii trunk .
    i am trying to make the bass deep like a ported.
    i used poly foam but not deep like port still trying
  9. aznboi3644
    If you want deep bass within a small enclosure...you need more power.
    Hoffmans Iron Law....read up about it.
  10. mrmizcue
    mrmizcue Full Member
    or try a slot port... some on the inside and some on the outside of the box
  11. G3n3R@1
    G3n3R@1 Full Member
    or u can use an enormous enclosure with enormous amounts of power hehe;) and ya a 2" port would sound like a hair dryer.
  12. xlaudio
    xlaudio Full Member
    ok
    ok
    mtx said i need a largrer enclousure to port it like 2.00each side, which i dont have.,
    o well will have to make th seal work.
