what am i doing wrong
Discussion in 'General Car Audio Discussions' started by taylor25, Feb 4, 2010.
  1. taylor25
    taylor25 Member
    i have a alpine pdx 1.1000 hooked to a jl w7 13 and its fine when u listen to music but as soon as it goes to hit a deep bass note it kicks the amp of and give it a second or too and it turns back on. So i thought i had it hooked up wrong so i took the sub out and checked it was right. Not knowing what to do i hooked my old setup back up an older eclipse 12 one of the aluminum ones with a 500 watt kenwood amp and it cut the sub but didnt turn off the amp im at a loss and have no idea what to do someone plz help
  2. fstrfvo
    fstrfvo Full Member
    What gauge wires are you using? Check all your connections, terminals etc. do your lights dims at all when cranked?
  3. taylor25
    taylor25 Member
    yea they dim and ive checked all the connections but as of right now im using one of those cheap instilation kits i have 2 gauge wire to put in but i dont know why it didnt do it to my old system but it does now
  4. pedro quiroga
    maybe your batt is slowly going dead. have your charging system checked to make sure its ok.
    do the big 3 also.
  5. fstrfvo
    fstrfvo Full Member
    just take into account all amps have a certain voltage range in which they can operate, so if your electrical system is dropping below the amps low voltage point it will cause it to shutdown. Put a meter on the battery when the car is running and the stereo cranking, you will the voltage jump up and down, see how low it goes, then you will have a better idea of whats going on.
  6. taylor25
    taylor25 Member
    thank u guys i work at advance auto parts so ill check it tomorrow when i go in and im really new to all of this stuff i just want to thank u again for all the help i had no idea that a loss in voltage could shut it down and i know this is probably a dumb question but what is the big 3
  7. Kvo_8
    Kvo_8 Full Member
    big 3 = upgrading battery -/alt to batt +/engine -
