hello everybody excuse my bad English, I'm form Jordan and looking for 2 orion sub 12" and orion amp (i don't know how many watts i need for amp to make those 2 sub work good), coz i can't find them in my country,so how can i buy them and how much the amp and the 2 sub equal,thanks regards walid
Hey Franky, I poked around on ebay and amazon and it looks like you'll be spending around $500-600 plus shipping for each sub(and they are heavy) and if you want to match their power with an amp also from Orion, then the only option I can find is for their HCCA 25001 mono block, and you might end up needing one for each sub. I've included links to websites you can buy this stuff from, and if you have the money to spend then go for it cuz these are some amazing subs but once you see the prices you may want to try soemthing a little bit less expensive. You should look into subs from Fi, DC, SSA, or Incriminator. They have some great stuff and its slightly cheaper than the Orions. Here's the Orion links http://www.onlinecarstereo.com/CarAudio/p_21140_Orion_HCCA-25001.aspx http://www.onlinecarstereo.com/CarAudio/p_17772_Orion_HCCA122.aspx Here's the links to DC Audio, SSA(sound solutions audio), Fi, Audioque and Ground Zero http://www.dcsoundlab.com/subsamps.html http://store.soundsolutionsaudio.com/categories/sub-woofers.html http://www.bladeice.com/index.php/products/fi-car-audio/sp4-series http://www.audioque.com/HDC-40-Series-Subwoofers-_c_25.html http://www.ground-zero-audio.com/en/products/subwooferchassis.html I hope this helps you out.
