10 seconds after I start my car I'll get a loud popping sound emitting through the speakers. I have a amp, subs, cap, 6x9's. Periodically, the pops will come every 5 min. or so. Thanks.
The 1st thing you need to do is check the wiring including the amp. Make sure all connections are proper and there is no grounding or shorts. Don't forget to check the rca's as well. This will more than likely eliminate the problem, let us know.
You didn't mention if you were running the facotry head unit or not, but if you are, there are sometimes turn on issues if the remote for your amp is not wired correctly. Make sure your amp is turning on at the same time signal arrives or you could have a pop when the amp turns on.
