Sorry for thinking "practical" for a moment... but my nutz are doing their trick of commandeering my brain again... And they are thinking survival, apparantly: "Good lord, why would you do that with a potentially armed weapon?" BLAM! good bye nutz, if not life...
He's got balls of steel? Then again, it's pointing up his ass.... not at the nutz At least point the gun the other way... less dangerous and maybe more comfortable?!?
I was thinking exactly the same thing.... And then I was thinking, maybe he was doing it this way so that the barrel opening wouldn't get scratched or damaged on the ground... And then I was just thinking of the irony of THAT... considering the "what if" of what might happen to the gun, and prioritizing that over the "what if" of what might happen to his balls... :lol:
*muah* yeah it fixed it. but of course now I have a major rust problem developing somewhere in my cooling system. radiator im 99% sure. not cool. Jeff
The radiator is aluminum and plastic... neither rusts Flush it again with clean water, put 50/50 anti-freeze and water in it, and find a "PH neutralizer" at O'Rieleys... I think Motor-Purr makes one available to the public. It should be in a clear glass cylinder, and it almost looks like honey. That should help. After running it for a couple weeks, use your DVOM and hook the ground to the battery ground, and place the positive lead in the coolant. Note the voltage present (there will be a voltage, corrosion is electrolisys after all ), and let me know.
wanna just gimme another call? I've already completely flushed out the cooling system and put a 50/50 mix in it. After a few days, it just turned all rusty again. So it's not the radiator, and I know it's not the waterpump because I replaced it just over a year ago (a nice one at that), so.....what's left? the engine block? I think it's time to sell....... Jeff
