Thread Tools | Display Modes |
#1 |
Junior Member
amp shutting off
i have a alpine pdx 1.1000 hooked to a jl w7 13 and its fine when u listen to music but as soon as it goes to hit a deep bass note it kicks the amp of and give it a second or too and it turns back on. So i thought i had it hooked up wrong so i took the sub out and checked it was right. Not knowing what to do i hooked my old setup back up an older eclipse 12 one of the aluminum ones with a 500 watt kenwood amp and it cut the sub but didnt turn off the amp im at a loss and have no idea what to do someone plz help
#2 |
Full Member
What guage power wire are you running? Have you checked all your connections, Ground etc.
__________________ ![]() 2001 Mercury Sable 24V DOHC Focal Polyglass 165V1 6.5 comps in front doors Focal Polyglass 570CV1 in rear deck Hifonics ZXI 3406 amp Diamond Audio 1000.1 D3 @ 2.6 ohms 3 12 inch Infinity 1252 reference subs wired @ 2.6 ohms JL Audio Cleansweep 1/4 awg wires stock 130 amp alt Duralast gold batt Kenwood 10 disc cd changer |
#3 |
Junior Member
yea ive checked all the connections and they all are good but the wire is from one of those cheap instillation kit but what i dont understand is when i hooked my old system back up it does it now but it didnt before and i had all the same wires and have changed nothing
#4 |
Full Member
maybe your battery or alternator are going bad?
do you have voltage drop? __________________ 1999 Jeep Grand Cherokee Laredo Duralast Gold, KnuKonceptz 1/0 Gauge throughout Power Acoustik 3 Farad Capacitor (Mainly For Looks) 2 Alphasonik 12's in Custom Ported Box Fusion 2500 Watt Class D Amp, Pioneer HeadUnit ( DEH-P3000IB ), Infinity Components, |
#5 |
Junior Member
well the volt meter in my dash doesnt drop a bit but idk how accurate it would be, i just started using forums and i found this site i just want to thank everyone for being so helpful
#6 |
Full Member
Well your amp is not hooked up to your gauge, its hooked up to your battery. You really cant rely on the gauge. Put a meter on the battery when the car is running and stereo is on fairly loud and see what happens. You can get a cheap meter at radio shack for like 12 bucks. What kind of car do you have?
#7 |
Moderator
a digital multi meter is your best friend in situations like this.
they have voltage meters in them too. how is your sub wired? could it be wired to too low an impedance? __________________ ELEMENTAL DESIGNS NNINE.1 wired @ 1Ω 2 RE sx 12's in a 4cf box tuned to 30HZ Elemental designs NINE.5 350 x 2 4 ohm mono. 2 polk 6.5 mid bass 2 mtx, 2 polk tweets kinetik 1600 duralast gold under the hood BIG 3 PIONEER DEH7800 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Great Deals on eBay |
