Car Audio Car Stereo
Go Back   Car Audio Forum > Car Audio And Electronics Technical Forums > General Car Audio Discussions
Home Forums Photo Gallery Register Search Today's Posts Mark Forums Read
Whineing noise!!!!
Reply
Thread Tools Display Modes
Old 03-06-2005, 06:11 PM   #1
Honest Bob
Senior Member
Honest Bob's Avatar
Send a message via AIM to Honest Bob
I got the typical whine that varies with rpm only when the engine is on. The weird thing is that it only happens on the front preouts the rear and sub preouts are fine and have no noise. I've also tried another pair of rca's.
It all happened after changing moving the ground to a diffrent location. I've since then moved the ground to two other places and its now back in its origonal spot where it was perfectly fine. Still whines. I've also regrounded the head unit. No go
any suggestions?
Honest Bob is offline   Reply With Quote
Old 03-06-2005, 07:42 PM   #2
The_Ancient
Senior Member
Send a message via AIM to The_Ancient
how many amps, how many grounds?
The_Ancient is offline   Reply With Quote
Old 03-06-2005, 09:37 PM   #3
Honest Bob
Senior Member
Honest Bob's Avatar
One amp at the moment. One ground. The sound is definatly comming from the head unit. The noise goes away when I unplug the RCA's from the amp. I'm gonna try out a new ground for the head unit. Dunno what good its gonna do being as the noise is not present on any of the other preouts.
Old 03-07-2005, 05:45 AM   #4
The_Ancient
Senior Member
well it is either that set of cables (since you said you tried a differant set I doubt it) or an internal grounding problem with the HU
Old 03-07-2005, 10:29 PM   #5
geolemon
Senior Member
Send a message via AIM to geolemon Send a message via Yahoo to geolemon
Sound goes away when you unplug the RCA's from the amp...
But does the sound go away when you unplug the RCA's from the HU, leaving them plugged into the amp?
geolemon is offline   Reply With Quote
Old 03-08-2005, 09:13 PM   #6
Honest Bob
Senior Member
Honest Bob's Avatar
Yes sir!
Old 03-09-2005, 06:01 AM   #7
The_Ancient
Senior Member
I say again
Quote:
Remeber I am the car audio god, not bow before your master
Old 03-09-2005, 02:12 PM   #8
forbidden
Member
Michael thanks for getting my ability to post squared away. To me as well it indicated a **** poor internal ground plane and I am going to make a guess that it is a Pioneer head unit. Unplug the antenna from the head unit and remove the head unit from the dash, does it still make noise? Run a temporary power and ground line from the battery. Tie the yellow and red lines on the head together and attach to the power line from the battery. If you still have noise then it is 100% a head unit ground plane issue.
forbidden is offline   Reply With Quote
Old 03-09-2005, 05:34 PM   #9
Honest Bob
Senior Member
Honest Bob's Avatar
Actually it be a Kenwood MP919. Nearly three years old I think.
Old 03-09-2005, 09:31 PM   #10
geolemon
Senior Member
If the noise goes away when you unplug the RCA's from the HU, you know the noise isn't coming in through the amp itself (or it would still be there), you know the noise isn't being induced into the RCA cables (or it would still be there), so you know it is upstream of the RCA cables...
...the only thing left is the HU itself.
I'd check your power connections - both power and ground. It doesn't have to be a ground issue - either would have the same effect.
However, there's probably a ton of wires crammed back there.. it could be a connection that came lose - did you recently have the HU out for some reason?
And it also does beg the question:
When the HU was installed, was a wiring harness adapter kit used, to allow you to simply plug the new HU into the car's factory harness?
I personally consider cutting factory wiring to be a sin... that fundamental. It is not only messy and opens the potential for poor quality connections and poor quality insulating, but also leads to headaches down the road when it is time to replace the HU... to say nothing of the warranty issues you'd have with dealerships for cutting any factory wiring - whether justified or not.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trying to fix amp noise Italianhawksfan General Car Audio Discussions 3 03-21-2009 03:03 PM
amp noise philmetz Car Stereo Amplifiers 2 09-28-2006 06:44 PM
alternator noise antlip Car Stereo Amplifiers 3 08-29-2006 01:05 AM
Bad amp maybe? noise problem mike83 General Car Audio Discussions 4 08-25-2006 05:13 PM
Noise!! Need help... mespock General Car Audio Discussions 6 08-14-2006 06:53 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Great Deals on eBay
Powered by vBulletin ® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
