POWER ACOUSTIK OV1-2000D questions
Discussion in 'Car Stereo Amplifiers' started by chriswms, Aug 28, 2007.
  1. chriswms
    chriswms Full Member
    Woud the POWER ACOUSTIK OV1-2000D amp be a suitable amp for 2 15" kicker cvr subs. that should put me at about 450watts a sub at 2ohms. and is that about how much power I want to be feeding them?
  2. mrmizcue
    mrmizcue Full Member
    look for an amp that is in your price range...then get the subs either 2 or 4 ohm...i would get a mono amp that goes to 1 ohm...then get 2x4ohm subs...that will put you at 1 ohm. Get the most out of the amp.
  3. danracer
    danracer Full Member
    i think that amp is at a great price...i like power acoustick amps...i have one right now w/ 2 15 audiopipes and it makes them bang really hard
  4. chriswms
    if you would go to 1ohm. what would be a decent amp for about 150 give or take a little that would push the 15's and be 1ohm stable and how hard do i actually want to push them? do i want to push all 500watts rms per sub that they can handle or a bump down from that? thanks
  5. chriswms
    just curious but wouldnt that be pushing to much to the speakers at 1 ohm. 750watts rms per sub? i believe theyre only rated for 5oo?
  6. G3n3R@1
    G3n3R@1 Full Member
    u have a volume knob:) lol
  7. mrmizcue
    just set the gain on the amp down a little. Who know's...you might need 2 more after a bit and you will already have the power to push'em
  8. electrolytic
    electrolytic Full Member
    If they are rated 500 watts rms i wouldn't push any more than that into them, they will fry.
  9. Jeffc879
    Jeffc879 Full Member
    they will fry from distortion first. 1500 rms from a 150 dollar amp? i find hard to believe, but if you get it dont use the bass boost and keep the gain hella low. if that amp was low thd and 1500 rms wouldnt we all have one? seriously.
