Pac 200 Amp Relay / Battery Isolator
Discussion in 'General Car Audio Discussions' started by electrolytic, Apr 8, 2007.
  1. electrolytic
    electrolytic Full Member
    Is this what i need i want to order one. It says relay/battery isolator they are the same thing no? If not can you post the model # because i can't find one that doesn't say /battery isolator
    http://www.sonicelectronix.com/item_5287_PAC+200.html
    Mobile Audio Relay and Battery Isolator
    200 Amps at 12V Continuous Power Handling
    300 Amps Surge Power Handling
    Switching Power: 10 - 16 VDC
    Draws Less Than 1 Amp When On
    Dimensions: 2-11/16" L x 3-5/16" W x 4" H
  2. electrolytic
    Battery Isolator, Battery Isolator, Battery Isolator, lol they all say that.
  3. TheViking
    thats what ya need
  4. electrolytic
    cool, thanks
  5. electrolytic
    Ugh the cheapest battery is still like $100.00 with taxes, i'm just going to go to the scrap yard and grab one for $20.00. Interstate is good?
  6. aznboi3644
    I wouldn't trust a junk yard battery...interstate makes good batteries though
  7. TheViking
    The cheapest battery is a hundred bucks?!?!?!?!?!!!!!!
    Try going to an auto supply store, hell, I even have got to say (as much as it pains me) go to walmart if ya have too.....generally an average battery will run around 40-60 bucks.....
  8. pedro quiroga
    is that cause your in canada?:eek:
  9. electrolytic
  10. aznboi3644
    That will work...what are the specs of that battery
    I like the top and side posts...makes for cleaner install
  11. electrolytic
    This is all it says.
    # Provides up to 495 CCA
    # 5 years total warranty
    # 1-year free replacement
    # 1-year Roadside Emergency Boost Service
  12. aznboi3644
    it will help a lil
