Results 1 to 2 of 2
Thread: Need advice for underseat bass/midbass
  1. #1
    Junior Member
    Join Date
    Apr 2012
    Posts
    1
    I am getting a JBL Ms-8 to integrate my VW RCD 310 system that came with the polo. active front comps and rear coax on doors.
    My question is which among these two will be the best to put under both front seats. i want it to play the midbass too as i like really warm and full sound rather than thin and boomy.
    i was thinking of having a 300hz active crossover from the Ms-8 to the subs. the pioneer's response is 30-1500hz while the kicker is 25-350hz.
    I love a good punchy beat (i listen to house/trance mostly and sometimes slow rock) but im not a basshead anymore like with the hip hop songs.
    Which would u ppl recommend? new suggestions are welcome.
    Pioneer TS-SW841D
    8" Single 4 Ohm Pioneer Subwoofer
    Power Handling:
    Peak: 500 watts
    RMS: 120 watts
    Impedance: Single 4 ohm
    IMPP Composite cone woofer
    3-Layer fiber woven radial surround
    Projected pole yoke with vented pole
    Cast aluminum basket with fin-shaped design
    Voice coil bobbin: glass cloth
    4-Layer, long voice coil
    Strontium Magnet Construction
    Rubber gasket
    Spring compression wire terminals
    Frequency response: 30-1500 Hz
    Sensitivity: 85 dB
    Kicker 10CVT65
    6.5" Single 2 Ohm CompVT (CVT) Subwoofer
    Shallow mount subwoofer allows for deep bass with minimum mounting depth
    Power Handling:
    Peak: 300 watts
    RMS: 150 watts
    Impedance: Single 2 Ohm
    Injection molded SoloKon cone
    Ribbed Santoprene surround
    Stitched surround for enhanced cone-to-surround strength
    Extra strong adhesive and stitching prevents the cone from detaching from the surround
    Spiralead tinsel lead technology weaves the tinsel leads into the spider
    Super rigid cone and 360-degree back bracing eliminate distortion
    Sturdy steel basket holds the subwoofer mounted firmly
    Steel basket features perimeter venting around the single voice coil
    Strong spring-loaded terminals
    Newly re-designed 2010 basket structure
    Includes a built-in steel clearance adapter plate, which replaces part of the enclosure wall to allow shallower installations
    Ventless pole piece for extreme power handling
    Shallow four-layer voice coil
    High-Temperature voice coil
    Powerful rear magnet
    Frequency response: 25-350 Hz
    Mounting depth: 2-7/8"
    Also found as: 10CVT65-2 ohm, CompVT652, CompVT 652, CompVT 6.5" 2 ohm, 2010 CVT652
    Kicker CVT82
    8" Single 2 Ohm CompVT (CVT) Subwoofer
    Power Handling:
    Peak: 400 watts
    RMS: 200 watts
    Mounting depth: 3-3/8"
    Also found as: 10CVT8-2 ohm, CompVT82, CompVT 82, CompVT 8" 2 ohm, 2010 CVT82
  2. #2
    Moderator Ranger SVO's Avatar
    Join Date
    Jun 2006
    Location
    Abilene Texas
    Posts
    2,547
    I have had good luck with the Pioneer woofer, and it will work in a very small air space. You may want to consider the Earthquake Series series woofer. Its another woofer that I've had personal experience with. If you use one of the shallow mount woofers, down fire it for best performance.
    The moving power of mathematical invention is not reasoning but imagination.
    Augustus de Morgan
    Truth does not change because it is, or is not, believed by a majority of the people.
    Giordano Bruno
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 1
    Last Post: 01-07-2012, 08:34 PM
  2. Sub or MidBass?
    By jrad in forum General Car Audio Discussions
    Last Post: 01-22-2010, 05:48 PM
  3. can i put a crossover for midbass ?
    By deadz67 in forum Car Stereo Speakers
    Last Post: 10-11-2009, 11:49 PM
  4. My Midbass Plans!!!
    By Feandil in forum General Car Audio Discussions
    Last Post: 02-16-2004, 11:33 AM
  5. What Are Good 8" Midbass/bass Drivers?
    Last Post: 01-14-2004, 07:18 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
